Trigger Movies From Start?!
  • Silicon Soul
    by Silicon Soul » Thu May 19, 2005 7:30 pm
    Sorry if I am missing the obvious, but can anyone tell me how you can trigger a movie to play from the start and then loop as normal.
    I can't seem to get it to play from the start - it just plays from wherever it is in the loop - when I toggle the on/off switch.
    Is there anything to do with different codecs that allow this? Or something obvious I can't see? Or is it not possible?
    Thanks for any replies...
  • Bill Gates
    Re: Trigger Movies From Start?!
    by Bill Gates » Fri May 20, 2005 10:08 am
    Simply re-click on the media (in the media panel) or press its associated key (by default it is 1,2,3,4,5,6,7,8,9,0).
  • Guest
    by Guest » Fri May 20, 2005 7:03 pm
    Cheers Bill G. - that helps!
