MiniMad stuck at reboot
  • AgentD
    by AgentD » Thu Aug 08, 2019 9:40 am
    Hi all!
    I have a permanent installation which has two MiniMad running with connected via Ethernet. One of the MiniMad seems to get stuck while uploading and I can't go pass it... I tried unplugging but it gets stuck in the same part. I also tried pressing three buttons(Red/Blue/Yellow) as well as two buttons (Red/Blue) but nothing happens.
    At the end of the stuck screen it says "kernel panic, not syncing..."
    I attached the photo of the screen. If anyone have any idea please help!! Thanks a bunch in advance.
    AD
    Re: MiniMad stuck at reboot
    by MADben » Thu Aug 08, 2019 3:24 pm
    hi,
    you should first restore your miniMAD's sd card, here's the procedure :
    - download first the image disk on the madMapper yourspace page : https://madmapper.com/yourspace
    - download the Etcher app as well : https://www.balena.io/etcher/ (the link is also available on the yourspace page)
    - then all the steps are explained in the page 13 of the miniMad manual : https://madmapper.com/wp-content/upload ... RGUIDE.pdf
    The image disk is huge - if the downloaded file doesn't work it's mostly due to a download fail at some point, you'll have to download the image disk again.
    (by the way, always prefer the sd card which comes with the miniMad unit and above all avoid cheap ones)
    Plus, if after flashing the sd card your miniMad fails to start, it's possible that there's some dusk stuck in the unit sd-card reader - you can try removing the card and blowing air in the slot to clean it.
    let me know!
