microSD detection problem
  • edwardli
    by edwardli » Wed Aug 21, 2019 5:23 am
    Hi, I've recently purchased 2 miniMAD and tried to export the show, however the MadMapper could not detect the SD card at all using my MacBook's SD card reader.
    The card is shown correctly and detected by Disk Utility
    After hours of reflashing using the downloaded image, activating the card using miniMAD etc, nothing works.
    Eventually we found a really old external SD card reader, plugged Mac Pro, and viola!
    So what is the actual requirement for detecting the card? Even I could reflash the card (so the original reader must work), it cannot be used with MadMapper
    Thanks
    Re: microSD detection problem
    by MADben » Wed Aug 21, 2019 3:12 pm
    hi,
    it's somehow tricky but sounds like an sd card issue (it flashing the sd card did not solve the problem)
    could you contact the garageCube team on support@garagecube.com ?
    we'll answer shortly
  • edwardli
    by edwardli » Wed Aug 21, 2019 8:19 pm
    I'm quite sure it isn't the SD card issue (since I've got 2 microSD card + 2 adaptor)
    Flashing + validating image returns success, so it can't be the card problem.
    The flashed or unflashed microSD card could be detected immediately right after I switch to another card reader.
    Thanks for the reply, will be sending an email for this matter
    by MADben » Thu Aug 22, 2019 4:30 pm
    thanks for the precisions,
    Received your mail, we'll answer shortly -)
    by Pierre Guilluy » Thu Aug 22, 2019 4:33 pm
    Couldn't it be your MacBook's SD-card reader that's faulty?
    What happens if you plug your old SD-card reader to your MacBook?
