Assign Selected Media to Selected Surface via MIDI?
  • bloomfieldtony412
    by bloomfieldtony412 » Wed Aug 21, 2019 6:13 am
    I'm looking to use a midi button to assign the currently selected media to the currently surface.
    I see that there is a simple "assign" function for a specific media and that there is an "assign to all surfaces" function for the currently selected media.... but I can't find a way to press a button and apply the media I have selected to the selected layers.
    If I could do this, I could use a knob to scroll through clips, a few buttons to select layers, and then another button to launch the selected clip as desired.
    Hopefully I'm just missing something!
    Thanks,
    T
    Re: Assign Selected Media to Selected Surface via MIDI?
    by mad-matt » Thu Aug 22, 2019 1:55 pm
    Indeed the "/medias/selected/assign" control is missing. Will be added in 3.7.2. Should be out in a few days together with a bunch of fixes.
