Soft Egde
  • papet33
    Soft Egde
    by papet33 » Sat Aug 24, 2019 4:39 pm
    Good morning;
    I use Mapmapper for a musical theatre association.
    This year, we are projecting theatre sets from two projectors on a 5-meter high and 8-meter wide tulle screen. (which corresponds to the background.
    We perform in three different locations, the screen dimensions are adapted each time.
    In Madmapper I made 20 different scenes corresponding to the funds projected during the show.
    I created two different quads following the Soft Edge tutorial, so far it works well, but I am obliged to create and modify the quads for each scene and it is very tedious.
    Isn’t it possible to create just two quads for all the scenes?
    Thank you for your help;-)
    Cordially
    Re: Soft Egde
    by mad-matt » Sat Aug 24, 2019 9:46 pm
    Sure you can use only two quads if you have a single visual to project at a time.
    You can also update the quad position, warping and soft-edge settings in all scenes in a single operation. Please check this post: viewtopic.php?f=29&t=10463#post_content32488
  • papet33
    Re: Soft Egde
    by papet33 » Sun Aug 25, 2019 9:08 am
    Good morning,
    Thank you very much, that’s really great. :D
