Selecting Primary GPU
    caneron
    by caneron » Tue Sep 03, 2019 8:23 pm
    Currently, MadMapper will alert you to tell you to make your primary system display using your best GPU, this is a great little reminder.
    However: in a setup where your control monitor is on a different card than on your outputs, it's quite troublesome because your system controls are all hidden behind of video display.
    The setup:
    8@4k out of 2x P4000 cards
    1@1080 out of the onboard card (for control)
    The workaround is to have all the windows you need open on the control monitor before you go into show-mode.
    It would be great if MadMapper allowed you to set which card you want for processing rather than using the system to make the choice for you!
    Re: Selecting Primary GPU
    by franz » Wed Sep 04, 2019 10:14 am
    +1
    caneron
    by caneron » Thu Oct 17, 2019 6:53 pm
    Wanted to add that not having the primary monitor being the MadMapper control window means accessing other stuff in Full-Screen mode is impossible unless already up in that control display.
  • aspeckmann
    by aspeckmann » Mon Jan 27, 2020 2:39 am
    +1
  • tontechnik
    by tontechnik » Tue May 05, 2020 6:51 pm
    The setup:
    +1
