OSCQuery Websocket
  • BigHoss
    OSCQuery Websocket
    by BigHoss » Thu Sep 05, 2019 2:09 pm
    Hey there,
    i am working on a remote application vor MadMapper once again.
    Now that madmapper support OSCQuery for quite i while i thought i will give it another shot.
    I saw that there are some things missing in the oscquery implementation, or maybe i am just doing it wrong.
    HOST_INFO missing - in the Required Attributes the spec defines the HOST_INFO, but madmapper doesn't seem to have that.
    Bi-Directional Communication - Do you plan to add that function? or is there any other way to remotely add or at least duplicate an already existing Surface?
    Re: OSCQuery Websocket
    by mad-matt » Fri Sep 06, 2019 9:46 am
    Yes we don't support websockets actually (only http) and we don't handle bi-directionnal connection. We plan to implement it in a close future but can't promise a release date.
    There are ways to add surfaces and more possibilities (load project, save, save as, fullscreen on/off etc) with the actual release by activating an hidden setting:
    on Windows, in Cmd.exe:
    REG ADD HKCU\SOFTWARE\Garagecube\MadMapper /f /v enableApplicationController /t REG_SZ /d 1
    on macOS, in Terminal.app:
    defaults write com.garagecube.MadMapper enableApplicationController 1
    Then, restart MadMapper, you'll see new controls in /application/...
    Thanks for your feedback!
Users browsing this forum: No registered users and 64 guests
