New Fixture - Drop Down
  • ledinstallations
    by ledinstallations » Fri Sep 06, 2019 12:27 pm
    Hi.
    I'm working with a fixture that has preset effects at different driven values. Is it possible for me to create a drop down type menu from the fixture editor, so rather than having to move the slider, I can simply select it from a list?
    Many thanks.
    Chris
    Re: New Fixture - Drop Down
    by mad-matt » Fri Sep 06, 2019 3:09 pm
    Hi Chris,
    This is actually not possible, a good feature request though... I added it to our whishlist.
    Kind Regards,
    Matthieu - MM team
  • ledinstallations
    by ledinstallations » Sat Sep 07, 2019 11:43 am
    Thank you for your response.
    Is there a way to change the default value of a slider?
    Chris
    by mad-matt » Sat Sep 07, 2019 10:03 pm
    No, but you can select all your fixtures and change the slider value for all at once. So it's quite easy. Good feature request though. At some point we'll refactor the fixture definitions but that's not our priority at the moment.
