Kinect Masker and Windows
  • sputnik
    by sputnik » Fri Sep 06, 2019 9:32 pm
    Just wanted to double check if Kinect Masker works only on MacOs ? I am on Windows and using 'spout in ' to bring kinect silhouette from other software. Is there any other simpler method within Madmapper (on Win) ?
    Re: Kinect Masker and Windows
    by mad-matt » Sat Sep 07, 2019 10:05 pm
    We haven't ported the Kinect Masker on Windows at the moment. It's not a big task but not in our priorities at the moment. I think better solutions are coming for depth cameras so we might invest energy in newer and more efficient and reliable technology.
  • sputnik
    by sputnik » Sun Sep 08, 2019 11:18 am
    Ok.Thx for the info. Looking forward to this then !. In the meantime will keep using good old kinect .
  • kotzreizol
    by kotzreizol » Tue Sep 17, 2019 4:30 pm
    hi..
    @spunik which software is used for it. and it would be possible to describe the exact structure.
    many thanks...
  • sputnik
    by sputnik » Tue Oct 01, 2019 2:37 pm
    hi..
    many thanks...
    Hi First you have to install spout plugin from here http://spout.zeal.co/. Later you can use Touchdesigner or Unity (or any other) for kinect input .Use sample project for either how to obtain kinect depth camera view , then spout out from these programs. Madmapper will communicate thru spout protocol and will find this source.
