micro SD CARD setup for MINI MAD
  • andyakareach
    by andyakareach » Thu Sep 26, 2019 1:35 pm
    I just bought a micro SD card 16gb.
    Could you assist me how I need to setup the micro SD Card so I can export my setup to MiniMad ?
    Thank you,
    Andy
    Re: micro SD CARD setup for MINI MAD
    by MADben » Thu Sep 26, 2019 3:27 pm
    Hi Andy,
    Just answered you by mail -)
  • nchlshodge
    by nchlshodge » Tue Mar 03, 2020 10:24 pm
    I am having this trouble with my miniMad. MiniMad isn't automatically running the program from the SD Card. I assume it's cuz the micro SD CARD got reformatted. How do I format it so it works with mini?
    by Pierre Guilluy » Wed Mar 04, 2020 2:46 pm
    Please refer to the "UPDATE YOUR miniMAD SD-CARD" section in the miniMAD user-guide:
    https://madmapper.com/wp-content/upload ... RGUIDE.pdf
  • SuchyReithler
    by SuchyReithler » Mon Jun 14, 2021 5:02 pm
    Hello, I have the same problem that Andy had.
    I have got a new 16GB SD card and I flash it with the right 16GB file, but it won't come in my MadMapper.
    What I haven't understand and what I need to do? Thanks!!
    by Pierre Guilluy » Wed Jun 16, 2021 9:08 am
    Did the flash procedure succeed using Etcher?
  • SuchyReithler
    by SuchyReithler » Fri Aug 20, 2021 10:56 pm
    Yes, I have done the process using Etcher. With the SD card in the Minimad linked to a hdmi screen, I have followed the instruction and pressed the red, yellow, blue button.
    But when I use Madmapper and I insert my SD card, nothing month in the program, so I'm stuck!!
    By the way, I dont understand why Garageband haven't done the thing simple, and haven't included this process directly in Madmapper. All this stuff downloading stuff with low connection which cut sometimes and flashing procedure, is a pain in the ass.
    by MADben » Mon Aug 23, 2021 10:31 am
    MiniMad are shipped with an activated SD card so you dont have to format the card and therefore download the -huge- image disk.
    the image disk can't be reduced and I agree it's a pain to download such a huge file especially when you're already trying to fix an issue
    Your feedback will be shared though since improving the minimad is always in our priorities
    you said your sd card doesn't mount in MM, but does the card actually mount in your system?
  • SuchyReithler
    by SuchyReithler » Tue Aug 24, 2021 3:46 pm
    Thanks for your answer, seems that the disk Minimad mount, Is there another partition that should come?
    My roommates destroyed the first SDCard using the minimad for our MadLedLustre. That is why I tried to do an another one.
    The SDCard, seems to be activated:
    by Pierre Guilluy » Wed Aug 25, 2021 4:35 pm
    Ok, so your new SD-card is up and running.
    The MINIMAD partition is the only one available from macOS & Windows.
    We've recently discovered a problem we failed to reproduce so far: for some reason, a /Volumes/MINIMAD folder could still exist even though the SD-card has been ejected... Because of that (empty) folder, macOS will mount the MiniMad SD-card in a new /Volumes/MINIMAD 1 or something similar, and because MadMapper is focusing on a MINIMAD volume, it doesn't get the SD-card.
    So, please try this:
    1. Make sure no MiniMad SD-card is plugged in your computer, and MadMapper is not running
    2. Check if /Volumes/MINIMAD exists by copy and pasting the following line in the Terminal:
    ls /Volumes/MINIMAD/
    3. If it exists (= the previous command didn't return any error), the solution is to remove /Volumes/MINIMAD folder using the Terminal again:
    sudo rm -r /Volumes/MINIMAD/
    Then, you can insert the MiniMad SD-card in your computer again, launch MadMapper, and the SD-card should appear in the export dialog again.
    Please let us know.
    by Pierre Guilluy » Wed Aug 25, 2021 5:21 pm
    In the meantime, I've been able to reproduce the problem artificially (still not knowing how it can happen), and it should not be a problem anymore in coming MadMapper 4.2.
  • SuchyReithler
    by SuchyReithler » Thu Aug 26, 2021 12:49 pm
    Perfect, it's work...
    Thanks for your investigation and research!! :D :D
    by Pierre Guilluy » Thu Aug 26, 2021 4:49 pm
    Great, thanks for the feedback!
