Audio and video length issues MADMAPPER 3.7.3
  • fvweick1991
    by fvweick1991 » Wed Dec 04, 2019 1:33 am
    1 problem)
    I try to display a video in madmapper I leave the audio enabled, when I play it does not display, and if I play dnv the duration increases like 0.80 but still locked.
    When I mute the video flows and it works.
    2) Problem Certain videos have a certain duration 10-8 minutes when I go to show them they get stuck in 3 minutes or some short time sometimes even seconds.
    I have to delete and relocate the file to work.
    before it worked is problem 1 had never happened, now this constant.
    Problem 2 happens whenever I use scenes and cues works well and suddenly the bug starts.
  • fvweick1991
    Re: Audio and video length issues MADMAPPER 3.7.3
    by fvweick1991 » Fri Dec 06, 2019 7:46 pm
    The first defect was in the audio output and managed to solve.
    But the second defect is not: the videos that need to be discarded are the times that their duration lasts to be shown in between.
    Then I need to delete a media and put again.
    What happens is the video is 5 minutes long, and it gets about 2, 3 minutes.
    how to fix?
    by mad-matt » Sat Dec 07, 2019 7:00 pm
    Can you reproduce it easiely ? What's your codec ? Does it happen with audio deactivated ?
    I will send you another app version. Let me know if it solves.
  • fvweick1991
    by fvweick1991 » Sat Dec 07, 2019 7:59 pm
    yes I can easily reproduce, the duration of the clips changes alone. Especially when using scenes and cues, H264 codec often changes the length of a video that I haven't even shown yet. Then I need to delete and reopen to enter with all the duration and hope not to crash. I updated to version 3.7.4 and continues to tweak from time to time, I'm dropping everything manually because then I can see the duration and fix before releasing.
    thx for sending new version, you have for windows 10 ?
    by mad-matt » Sat Dec 07, 2019 9:40 pm
    The duration changes because we encounter an error while decoding. The question is in which circumstances this happens. We did some changes in the movie player in 3.7.5 that might solve.
  • fvweick1991
    by fvweick1991 » Sat Dec 07, 2019 11:39 pm
    Not Work ;(
    by mad-matt » Sun Dec 08, 2019 10:21 pm
    Could you send me the problematic file ? We'll try to reproduce the issue and see why this happens.
    In the meantime you can recompress to HAP codec, that's the best and MadMapper has a native decompression for that: https://hap.video/
    by mad-matt » Mon Dec 09, 2019 1:42 pm
    Okay we found out the issue. We're building 3.7.5 with the fix. Thanks !
    by mad-matt » Wed Dec 11, 2019 11:34 am
    3.7.5 is now the official release. Thanks !
