videos/pictures and sound at the same time
  • simonhu
    by simonhu » Wed Dec 04, 2019 5:51 pm
    Hello MM community
    I would like to set on the keyboard 0-9 to cue a video or a picture. Once started, the video shall stopp when I push another button.
    But I would like to start another buttons (A, B, C) for some noise effects (videos with no content) which should work independently and at the same time as videos/pictures 1-9 run.
    On the cue matrix twoo points should appear at the same time.
    How can I achieve that?
    Thank you for your help.
    Re: videos/pictures and sound at the same time
    by mad-matt » Fri Dec 06, 2019 11:31 am
    Using Cues:
    - map the series of button for you images/video content, those are just storing the surfaces dedicated to display (drag&drop all those surfaces on cue cells)
    - map the series of button for audio to some other cue cells (choose another grid row or color to make things clear) , those cues are just storing the surfaces dedicated to audio (drag&drop all those surfaces on cue cells)
    MadMapper 4.0 will come with an audio player module, so you can drag&drop an MP3/wav/ogg etc. and cue it easiely.
