Play material/scene exactly one round after button pressed
  • projectfirefly
    by projectfirefly » Thu Dec 05, 2019 12:21 pm
    Dear garageCube/MadMapper community
    I want to have an interactive light show controlled by a MIDI keyboard.
    When a certain key is pressed, I want the connected material/scene to play exactly one round/one time and not to toggle it so it loops all the time.
    I also could not yet figure out how to set a time to the toggled material/scene and would like to ask you guys for help!
    Thank you for your help and best regards
    Timon
    Re: Play material/scene exactly one round after button pressed
    by mad-matt » Fri Dec 06, 2019 12:29 pm
    Hi !
    I don't understand your requirement. A Material might be a noise, there is no real start / end. For a movie, you define a loop start / end, but for a material I don't see.
    So what do you mean by "I want the connected material/scene to play exactly one round/one time" ?
  • projectfirefly
    by projectfirefly » Fri Dec 06, 2019 3:03 pm
    Hey Matt
    Thank you for your fast reply.
    I will try to explain my project with more details:
    I have a wall with LED pixel strips on it. If I press a key (e.g. 'L'), I want to toggle a light-line which moves from the left side to the right side of the wall exactly once.
    When the light-line is moving from left to right and I am pressing the 'L'-Key again, an additional light-line should appear and move from the left to the right side exactly once.
    I tried to work with scenes/cues with timer and the MadMapper preset 'Line'-Material but I could not find a satisfying solution to my problem so far.
    If you have further question please do not hesitate to ask.
    Best regards
    Timon
    by franz » Fri Dec 06, 2019 5:06 pm
    you can reset the timebase of any material. that's the "restart" button. you should cue it as well.
    does that work for you ?
