Locked 9 posts Page 1 of 1
MadMapper v4 BETA Available
    by MADben » Mon Dec 09, 2019 5:54 pm
    Dear users,
    We are pleased to announce you the availability of the MadMapper Version 4 BETA!
    The next version of MadMapper will hopefully delight you with a host of new features and improvements, some of which have been requested for some time.
    Time to break the limits! Time to enjoy a fresh new version of MadMapper!
    We are excited to release this Beta version! Your precious feedback and bug report will help us improve the software, please share them with us -)
    Users already registered within the Beta program will receive a newsletter in the coming days with a direct download link.
    If you're not registered to the Beta program yet, you can do so on the MadMapper yourspace page!
    https://madmapper.com/yourspace
    Find the release notes below.
    - the MADTeam -
    MM 4.0 Release Notes
    ADDITIONS
    + Surfaces:
    - Quad, Circle and Mask surfaces can have multiple masks, user drawn, made of editable Bezier Paths
    - Added Feathering on Quad, Circle, Triangle, Mask & Lines and on surface sub-masks
    - Quad / Circle Masks can be drawn and attached to the input media (attach to Quad / Input or Nothing)
    - Lines have been completely rewritten to be bezier paths, with user defined shape and joins
    - Added an option to generate lines from surfaces/fixtures outlines
    - Lines: improved animations and performances (single draw call for a whole line container)
    - Surface Groups have their own opacity / color levels - child surface will be affected (their opacity / RGB will be multiplied by their parents)
    - Surface Groups remember their perspective transform (stored in project)
    + New Quad mesh warping:
    - Points can be added freely in the quad (Alt+Click)
    - Added possibility to select and move a mesh warping horizontal/vertical segment / line
    + Added Surface Preview Groups: groups of surfaces that will made visible in the preview while being invisible in the output
    + Scenes / Cues:
    - Added the possibility to create / remove Cue Banks
    - Cue Bank "Live mode": pressing a cell will trigger the cue, no editing possibilities, just live triggers (nice with touch screens)
    + Workspace: added the possibility to define a folder at any location on the filesystem as the workspace, enabling sharing MadMapper resources in between machines through a file-sharing service like Dropbox, using specific workspaces for different projects, etc
    + Audio Player module: drag & drop your audio files (mp3, wav, aiff, etc) in MadMapper, create cues with it...
    + New integrated Shader Editor (to edit Materials)
    + MadLight Recorder:
    - Added an option to record incoming DMX (from another application / light desk)
    - Added support for audio playback (with multichannel support) with audio/DMX tracks synchronisation option
    - Added playback modes
    - Added a sequence edition mode
    - Recording Start & Stop buttons are mappable / cueable
    + miniMAD Light:
    - Support playing back audio file (with multichannel support - plugging a USB audio card to the miniMAD) with audio/DMX tracks synchronisation option
    - Support Artnet unicast with devices which don't handle ArtNet Polling (using the unicast table defined in MadMapper)
    + miniMAD Video:
    - Support surface Feathering / masks (with feathering) / mesh warping for Quads
    - Support Quads, Circles, Triangles, Masks
    - Added a "direct-to-framebuffer" video playback mode for optimal performance when used on a screen (when no mapping / perspective correction is required)
    - Optimised graphics engine
    + UI:
    - Cue Bank, Material Library, Fixture Editor, DMX Monitor etc. can be integrated in the UI or extracted and moved to an external screen
    - Focused widget (Surfaces, Fixtures, Media, Modules, Masks...) is reflected by a lighter color, it will handle copy/paste/duplicate etc.
    + Improved editing in preview:
    - Single click to enter / leave edition of a mask / line
    - Click and release on actually selected surface will select the first surface behind it (circular selection)
    - When a surface is selected TAB => select next surfaces, when a handle is select => Alt+TAB select first handle of next surface...
    + Added Master Levels in master tab: Master (video and DMX) / Video Master / DMX Master / Audio Master
    + New DMX Monitor with definable column count
    + Multi-instance for videos, image folders & Quartz file: you can import the same movie twice and control them independently
    + DMX Fixtures: added an option to define if a fixture slider should be affected by fixture luminosity (control a beamer PAN / TILT, luminosity will only affect RGB)
    + Calendar Scheduler module: put your scene/cues triggers in a google calendar or another calendar application, export it to standardized format ICS, and import it in MadMapper! No internet required, safe for install!
    + New FXs
    + New Generator: Audio Graph
    + New Oscillator Bank module
    + DMX
    - Support DMX Input control through sACN
    - Added an option to deactivate ArtNet / sACN synchronisation (some device don't handle it properly)
    IMPROVEMENTS
    * Overall user interface improvements
    * Improved Material Library, supports drag & drop of a local or online material on previews or in media list
    * Better feedback when a DMX / Audio input/output device failed to start
    * Improvement playing back movie audio tracks
    * BackMagic: Added a new preference to enable Blackmagic devices through system compliant drivers (some BlackMagic devices must be handled with OS component - ie Web Presenter)
    * Updated to NDI 4.1 (supports NDI Hx, ie 4k streaming from NDI Camera mobile app)
    * Align / distribute / Resize when surface groups are selected handle group as an item (not treating each child surface individually)
    * When dropping visual files to output preview, create surfaces in current surface group
    * Improved MadLight sequence edition
  • AEK_98
    Re: MadMapper v4 BETA released soon
    by AEK_98 » Tue Dec 10, 2019 8:20 pm
    There is no download link in my user area. How to download a demo?
    Andrey.
    caneron
    by caneron » Wed Dec 11, 2019 12:28 am
    woo can't wait thanks
    by Pierre Guilluy » Thu Dec 12, 2019 5:48 pm
    MadMapper 4.0 Beta 1 is now available on Yourspace!
  • metamind
    Re: MadMapper v4 BETA Available
    by metamind » Thu Dec 12, 2019 9:26 pm
    Hi, I just downloaded in my mac:
    MacBook Pro (Retina, 15-inch, Mid 2014)
    2.5 GHz Intel Core i7
    16 GB 1600 MHz DDR3
    NVIDIA GeForce GT 750M 2 GB
    Intel Iris Pro 1536 MB
    Mojave 10.14.6
    And keep crashing every time when start up screen shows up.
    Cannot make it run.
    "What is important to us is that the emotional impact of the film is translated into concrete, positive acti
    by mad-matt » Thu Dec 12, 2019 9:42 pm
    Did you send a crash report ? If MadMapper doesn't come to the point of detecting crash logs, can you send it manually ?
    They are be located in ~/Library/Logs/DiagnosticReports/ (Finder / Cmd+SHIFT+G / Paste "~/Library/Logs/DiagnosticReports/" / Enter)
    Thanks !
    by Pierre Guilluy » Thu Dec 12, 2019 9:55 pm
    16 GB 1600 MHz DDR3
    Mojave 10.14.6
    Cannot make it run.
    I've just successfully tested on the exact same Mac as yours, also running macOS 10.14.6.
    Could you copy & paste your crashlog so we can fix the problem?
  • h3dproject
    by h3dproject » Tue Dec 17, 2019 1:46 pm
    Will the usb audio card option also become available for Minimad Video?
    by Pierre Guilluy » Tue Dec 17, 2019 2:27 pm
    Eventually we'd like to have USB-audio support in miniMAD Video as well, but we don't have any specific date for that yet.
