Locked 2 posts Page 1 of 1
MadMapper v4 BETA 2 available
    by MADben » Fri Dec 20, 2019 4:25 pm
    Dear users,
    We are glad to announce you the release of MadMapper version 4 BETA 2!
    It comes with several fixes listed below + the addition of an Audio Analysis feature and it's already available on the MadMapper yourspace page :
    https://madmapper.com/yourspace
    Your precious feedback and bug report will help us improve the software, feel free to share them with us on this address: userfeedback@garagecube.com
    Enjoy!!
    - the MADTeam -
    MM 4.0 Beta 2 Release Notes
    ADDITIONS
    + Audio Analysis: "MadMapper Output" can be selected as input (use the audio of your movie tracks & audio players for audio reactive materials or for Audio Controls)
    + Added Reset Locations in the View menu
    IMPROVEMENTS
    * miniMAD Video export settings are now saved in the project
    * Blackmagic ATEM Mini & Blackmagic Web Presenter are now listed in video-input list
    FIXES
    - If a surface is invisible on output but shown in preview (through preview group), audio should not be active
    - Bug fix in FFMPEG Movie Player with some pixel formats
    - Fixed issue with mask drawn on input media
    - Fixed keeping cross cursor after pressing “Add Warping Point”
    - Fixed possible startup crash on Windows (depending on audio devices)
    - Various fixes
  • Robbie the Robot
    Re: MadMapper v4 BETA 2 available
    by Robbie the Robot » Tue Dec 24, 2019 2:27 pm
    I'm experiencing an issue with MM4 beta 2. When I open a project I previously created with MM4 beta 1 the CPU spikes to 100% continuously for all cores. If I reopen the project in beta 1 everything returns to normal. The Activity Monitor shows MadMapper and VTDecoderXPCService using almost all the CPU power. I have sampled the processes and can send them to you if they are helpful.
    Screen Shot 2019-12-24 at 20.51.07.png (248.08 KiB) Viewed 13785 times
