Fixture Led Barre
  • maquenchie
    Fixture Led Barre
    by maquenchie » Fri Jan 10, 2020 1:31 am
    Hello everyone, I have a problem in creating the fixture for 2 of my new lights: the "LED IP Bar 320/8 RGB DMX IP65".
    My problem is the following : the bar is cut in 8 RGB led segments so far no problem, creation of an 8 pixel wide fixture with 3 channels except that...the LED bar has 26 and not 24 channels, it has a channel "Dimmer for all led" in 1 and "strobe" in 26.
    -Is there a technique to exclude some channels during a repetition on several pixels because mad only proposes to me to distribute the channels on the different pixels but does not allow me to make it work independently..
    THX...
    Re: Fixture Led Barre
    by mad-matt » Sun Jan 12, 2020 1:32 am
    You have to cut your device in 3 fixtures:
    - fixture one: a single 8 bits slider (which you'll patch to first channel of your device)
    - fixture two: the 8 RGB pixels fixture (which you'll patch to second channel of your device)
    - fixture three: a single 8 bits slider (which you'll patch to last channel of your device)
    Then you duplicate those 3 fixtures for each device !
