Global BPM - Urgent ISSUE
  • Mjason
    by Mjason » Tue Jan 14, 2020 2:45 am
    Hi! We're doing a production where we use both Ma2 and Madmapper for lighting design. However, as we're working with a music act and we cannot have the ableton live set at Front of House, we cannot do the madmapper bit over MIDI. We've done it with midi over network before but it is way too inconsistent and unreliable.
    So, we are having the Ma2 controlled by timecode, and we're triggering madmapper with Dmx From Ma2. But this is where the issue in madmapper occurs.
    Is there any way to set the BPM of the project to update with the cues instead of being global? We're currently sending dmxmapping from ma2 to madmapper to trigger cues, however the BPM doesn't follow the cues which makes it pretty much useless.
    Thank you!
    Re: Global BPM - Urgent ISSUE
    by franz » Tue Jan 14, 2020 6:17 pm
    The BPM slider in the master tab is cue-able,
    but the TAP button as well, so you could either send a DMX tap from the grand ma or cue the BPM values .
