korg nanokontrol2 sliders reversed
  • brad2600
    by brad2600 » Sat Jan 18, 2020 3:18 am
    i'm having an odd problem. a few years ago, i switched to an akai controller, moving away from the nanokontrol. today i bought a fresh nanokontrol, as i missed the tiny size.
    i went to map the sliders, and slider 1 and 8 both seem to be reversed. as in, i push the slider up, and the fader in modul8 goes down. push the slider down, and the fader goes up. sliders 2-7 work as normal, its just 1 & 8 that work in reverse.
    i have tried it on two different computers, one running yosemite, the other running mojave, both on modul8 3.1.6. blank/new projects in both.
    did i do something simple, or is this controller just defective?
  • brad2600
    Re: korg nanokontrol2 sliders reversed
    by brad2600 » Sun Jan 19, 2020 4:00 am
    update: took it back to the store i bought it from, swapped it out for another, the replacement works perfectly
    by MADben » Mon Jan 20, 2020 5:31 pm
    "the replacement works perfectly"
    that's good news! thanks for the feedback though
  • brad2600
    by brad2600 » Mon Jan 27, 2020 3:32 am
    it was honestly so confusing that it had to be a bad controller. made sure to post the follow up in case anyone else encounters this!
  • annebakerim
    by annebakerim » Mon Jan 27, 2020 1:52 pm
    I have such a problem. I bought this device, but it refuses to work (((
    I have win 7 on a laptop. I installed all the necessary drivers. At the first connection, the sequencer saw the controller, but literally after 10 seconds, the sequencer lost the controller and that's it.
    My beech does not see this. It is not even determined by the software that comes with it - KOrg kontrol Editor.
    Repeatedly reinstalled the controller software. Useless (((
    However, on a neighboring prehistoric computer with XP, the controller works ...
    Who is to blame and what to do ))) :(
    by MADben » Wed Jan 29, 2020 4:54 pm
    Which sequencer?
