Output file name over OSC
  • solosails
    by solosails » Mon Jan 27, 2020 4:02 pm
    I am trying to set up a few things using Touch OSC, and I'm struggling to work out how to feedback from mM to Touch OSC the name of the currently selected file.
    If I make an OSC entry for
    Code: Select all
    /medias/select
    it gives a target range up to 255 and outputs some sort of decimal number for each file selected, (not the file name), but if you try to make an entry for
    Code: Select all
    /medias/select by name
    it only allows 1 target range (which shows the file name but only for one file) -
    Any help how to do this appreciated.
  • solosails
    Re: Output file name over OSC
    by solosails » Mon Jan 27, 2020 4:26 pm
    Ahhh, have found the problem, I was using the beta v4 - this is a bug in v4 by selecting the medias/select by name it only selects one then stops.
    by mad-matt » Wed Jan 29, 2020 12:33 am
    "/medias/select_by_name" is supposed to receive a string with the media name.
