Object manipulation using numbers
  • one11exo
    by one11exo » Wed Feb 05, 2020 5:45 pm
    Hey guys ;)
    Trying to set the positions of group of objects (3d cube with 3 quads aligned on each visible face) on stage and can't seem to locate numerical value of x,y, scale.
    here are a couple use cases:
    - i'd like to position each cube precisely instead of using my mouse, where would I find the panel to input X,Y ?
    - I'd like to change the scale of an entire group of object, where do I find "scale" ?
    Apologies in advance if that's super obvious :P
    many thanks!
    N
    manoly
    Re: Object manipulation using numbers
    by manoly » Mon Feb 17, 2020 2:55 pm
    +1 this is a good question!
    light up your space, share the path
    @missvisuales
Users browsing this forum: Baidu [Spider] and 44 guests
