TEXT GENERATOR
  • devicemesh
    TEXT GENERATOR
    by devicemesh » Tue Feb 11, 2020 8:02 pm
    New to MadMapper so apologies if this is a dumb question. I seem unable to have different text using the text generator in diferent surfaces. I add 2 quad surfaces and the text generator to both when I change the text on one surface it changes in both.
    Am i doing something wrong ?
    Thanks in advance
    Re: TEXT GENERATOR
    by MADben » Wed Feb 12, 2020 10:58 am
    I think you added only 1 Text generator : no matter what you'll do, triggering the settings will affect all the Text(s) indeed.
    Through the Media tab (right side) you need to add a second Text Generator with the "+" button.
    You'll then be able to modify these 2 texts in your 2 quads, independently
  • devicemesh
    Re: TEXT GENERATOR
    by devicemesh » Wed Feb 12, 2020 12:58 pm
    thanks very much :D
