First 1-2 scene skipping fast when main play button pressed
  • suraj_voxx
    by suraj_voxx » Thu Feb 13, 2020 12:31 pm
    I am new to Madmapper. I am facing this really strange problem. I have created 20 scenes in madmapper with different materials. When I Play, all scenes play in sequence each for 10 seconds(as set in settings). However every single time, first scene gets skipped fast.
    Note: I have checked many times. Everything is fine in this scene. I even replaced scenes with other.
    But still no matter what after hitting play, first scene just gets skipped in less than 2 seconds. After finishing whole sequence and when it loops, this scene play all perfectly fine. Its just that first time I play it simply skip to 2nd. I have tried everything. Still cant find solution for this.
    I also created new project and tried same with 4 scenes. timing set 10 seconds. But first scene always skips in less than 2 seconds.
    Any help would really be appreciated. I really need to resolve this on urgent basis.
    Re: First 1-2 scene skipping fast when main play button pressed
    by mad-matt » Thu Feb 13, 2020 5:54 pm
    This is not a known issue and I can't reproduce it.
    Did you check the option "Play next when the first movie loop finishes" ?
    Which version of MM ?
    Could you PM me your project file ?
Users browsing this forum: Baidu [Spider] and 50 guests
