restart with keyboard
  • redkap
    by redkap » Thu Feb 13, 2020 4:35 pm
    hi, i have a permanent project running a minimad ( which is hidden in the ceiling so i drive it with a wireless keyboard) , and sometimes , when power on site gets shut because of technical problem, the minimad is restarting, (and the projector is not).
    the problem is that the minimad is outputting a weird resolution , causing a mapping problem on the project.
    i was wondering if its possible to set a restart key on the keyboard for the minimad. in order to restart the rasp as the projector is already on.
    Macbook Pro / Mid 2014 13' / 8go ram
    Hackintosh I5 / 32go Ram / GTX 960- 4GO / El capitan. / Matrox triplehead2G0 SE / ARTNET 16 univers SJ-16 / LED strips 60l/m : total : 55m
    Re: restart with keyboard
    by Pierre Guilluy » Mon Feb 17, 2020 11:04 am
    In MadMapper / miniMAD 4.0 (actually available in beta on Yourspace), the miniMAD won't start rendering video until the projector / display is up and running, which should fix your problem.
    Anyway, I'm adding your suggestion to the miniMAD wishlist.
