Unable to launch MadMapper Demo 3.7.5 0n MacBook Pro
  • jsandeen
    by jsandeen » Sun Mar 01, 2020 6:40 pm
    I am unable to unable to launch recently installed MadMapper Demo 3.7.5 0n my MacBook Pro.
    Model configuration is:Mac OS Catalina, 10.15.3, 2,5 GHz Quad-Core Intel Core i7
    16 GB, Intel Iris Pro 1536 MB.
    At the same time I downloaded Windows version demo to a New Windows 10 PC and was able to lunch the demo on that machine. Any suggestions to trouble shoot running this on my Mac?
    Re: Unable to launch MadMapper Demo 3.7.5 0n MacBook Pro
    by MADben » Mon Mar 02, 2020 5:29 pm
    please contact the support on support@garagecube.com
    (please detail at which stage the application does not work as well)
    we'll answer shortly
    by franz » Wed Mar 04, 2020 5:40 pm
    can you expand on "unable to launch" ?
    does it crash, what happens exactly ?
    we need more info to help you.
  • jsandeen
    by jsandeen » Wed Mar 18, 2020 6:00 pm
    Currently I am working with Benoit on this issue through the support site. If and when a solution is found I will update with a reply. The issue I am having may be specific to my MacBook Pro. What is happening is that when I attempt to load the program it does not load, becomes unresponsive and I then have to force quit. Special thanks to Benoit for your assistance so far.
  • jsandeen
    by jsandeen » Sun Apr 05, 2020 7:30 pm
    After downgrading my MacBook Pro from Catalina to Mojave I was able to successfully launch MadMapper Demo 3.7.6 I suspect that their are problems with Catalina that had nothing to do with MadMapper. In addition to not being able to load MadMapper under Catalina I was experiencing the same "program is unresponsive" while trying to use zoom. Zoom would not recognize my camera, and would hang anytime I tried to do anything that involved video (my camera was working with FaceTime.) Thanks to Benoit for his help through tech support.
    by franz » Mon Apr 06, 2020 9:30 am
    I have MAdMapper running with Catalina, so I assume the problem was related to your computer...
    by MADben » Mon Apr 06, 2020 10:08 am
    like franz says, you can use MadMapper on Catalina indeed... - its fully optimized since a couple of versions
    Still, after reading your post about (all) the issues you had on Catalina, switching back to Mojave was a nice move (at least for now...)
    btw youre welcome, feel free to contact the support at anytime
