ASIO problems
  • simonegiusti
    ASIO problems
    by simonegiusti » Wed Mar 11, 2020 12:16 pm
    when switching to ASIO and then reboot MadMapper does not start anymore.
    No splash screen neither.
    I have to delete preferences entry in Windows Regedit.
    I tried with last version and with beta 4.0
    Re: ASIO problems
    by mad-matt » Wed Mar 11, 2020 6:10 pm
    Thanks for reporting. There might be an incompatibility between the library we're using for ASIO and an ASIO driver installed on your machine. Every people doing multichannel uses ASIO, so if it was a common case we would know.
    The best would be to have a crash dumb. Did you send some ? With your email ? If not, please send. You can also find them in:
    C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\.CrashDumps\
    And also send the log file:
    C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\Logs\
    Please send it to support[at]garagecube[dot]com specifying ASIO crash - for Matthieu, I'll take care of it.
