MadMapper 3.7.6. released
    by MADben » Tue Mar 17, 2020 6:00 pm
    Dear Mappers,
    We hope you're all well,
    We recently released a MadMapper v3 update with several fixes + the addition of the new garageCube 0.25m fixture :
    MM 3.7.6 Release Notes
    IMPROVEMENTS
    * Added garageCube SFX 0.25m fixture definitions
    FIXES
    - Fixed possible issue on macOS Catalina with AMD graphics card
    - Fixed Text Generator on macOS Catalina
    - Fixed an issue when visual audio level is linked to opacity
    - Show a message if we fail to create an OpenGL 3 context
    - Fixed possible issue on Windows starting app from a display not connected to the "Main Display" GPU
    - Fixed a possible issue when deactivating& reactivating NDI output on a projector
    - Fixed importing fixture definitions exported from MadMapper 4.0.0
    Available as usual on Yourspace,
    Enjoy!
    The MadTeam
    https://madmapper.com/yourspace/
  • balamsoto
    Re: MadMapper 3.7.6. released
    by balamsoto » Wed Mar 25, 2020 8:26 pm
    Install error
    Mac Catalina, signature problem
    by MADben » Thu Mar 26, 2020 6:38 pm
    Just download again the software + installed it properly,
    double-check in System Preferences / Security & Privacy / General if you need to "open anyway" the installer,
    and / or try a right-clic on the installer in order to launch it
    let us know
