One videomapping and one projection at the same time
  • anjemalo
    by anjemalo » Tue Mar 24, 2020 6:20 pm
    Hello:
    I need to ask you if your Madmapper software can do the following:
    From one computer in Windows with two outputs, we need to project one video mapping and at the same time with the other output one projection of normal video.
    Can do this with Madmapper?
    Can yo tell me what hardware and software do we need?
    many thanks
    Andres
    Top
    Re: One videomapping and one projection at the same time
    by MADben » Fri Mar 27, 2020 9:56 am
    Hi Andres,
    Basically within MadMapper you can setup many projectors. Apply a different content on each.
    It doesn't sound like a "complex" project. (I mean some are really complex) - so you may dont need a workhouse computer.
    + if you use HAP codec for your videos, you can get really good performances
    Feel free to share more insights here or via support@garagecube.com
Users browsing this forum: No registered users and 58 guests
