OSC API still valid ?
  • al_baum
    by al_baum » Sun Apr 12, 2020 8:29 pm
    I am trying to control some parameters via OSC and discovered this page : https://github.com/cansik/madmapperapi
    When I use this command as described /getControls?root=/surfaces/Quad-1&recursive=1
    I get a reply from Madmapper (in MaxMsp) with 46 possible controls. But when I tried to send an OSC message to some of these controls, nothing happens. I am particularly trying with :
    /surfaces/Quad-1/output/mesh_warping
    and with /surfaces/Quad-1/output/soft_edge
    None of these two are working. I tried several different spellings (changing underscore with upperscore, or capital letters) to no avail.
    Are these messages not available anymore ? Thanks
    Using Madmapper 4.00 Beta 9
    Best
    Re: OSC API still valid ?
    by mad-matt » Tue Apr 14, 2020 9:02 pm
    OSC API is still support, however it's deprecated in favor of standardized Osc Query:
    https://www.youtube.com/watch?v=1UTUR7M43no
    https://github.com/Vidvox/OSCQueryProposal
    "mesh_warping" and "soft_edge" nodes are there for technical purpose and are not meant to be controlled through OSC. We'll fix this so they don't appear in the API. You can check by pressing on the "+" button in the control list which nodes are meant to be used.
  • al_baum
    by al_baum » Fri Apr 17, 2020 8:39 pm
    O, thanks, I will check the osc query way,
    Best
