Playing a show
  • QuantumVirt
    Playing a show
    by QuantumVirt » Wed May 06, 2020 5:32 pm
    Perhaps a basic question and one I'm sure has been asked before but... I was looking for suggestions on the ability to add audio tracks, sound effects etc to a timeline of projection mapped scenes.
    For example I have several scenes I am having madmapper play through and I am looking for an easier way to set up a show to play through scenes on cue and add sound effects and make a sort of one click movie mapping play through with audio. Do I need to use Touch Designer to accomplish this? Is there an easier timeline software I can use to integrate with mapper to cue scenes and also place audio? Thanks! (6 months using MM)
    Re: Playing a show
    by mad-matt » Wed May 06, 2020 10:44 pm
    If you're on macOS Vezér is an affordable and nice solution.
    Ableton Live Intro is also enough for this and cost 60$, works on Windows and macOS.
