How to show HAP thumbnails in the mac finder?
  • te-c
    by te-c » Sun May 24, 2020 12:56 pm
    I've updated to Catalina and know my QuickLook Plugin doesn't work anymore. Anybody knows a workaround to look what all my videofiles look like?
  • te-c
    Re: How to show HAP thumbnails in the mac finder?
    by te-c » Wed Dec 09, 2020 12:59 pm
    Nobody has any solution? How do you manage all the content if you don't see them?
    I don't want to load all my stuff into modul8 or mad mapper every time. In the past I changed content while VJing. In 8 hour live visuals I need to change stuff.
    G4jima
    by G4jima » Mon May 09, 2022 10:52 am
    Wish there was a solution to previewing these HAP files on OSX it really is a pain i have installed the QL utility for thumbnails via brew using terminal, not sure if it works really for Big Sur.
    If you have installed homebrew you can add it this way
    brew reinstall --cask qlvideo
  • founderlock
    by founderlock » Sat Aug 20, 2022 3:50 pm
    Hope someone can respond. I can not install the QL utility.
    basket random
  • haseem alam
    by haseem alam » Wed Feb 07, 2024 9:39 am
    How do you typically manage your content during live visuals if you're unable to see thumbnails, especially during extended sessions like 8-hour performances?
  • te-c
    by te-c » Wed Jun 26, 2024 3:29 pm
    Sorry for late reply, wasn't in the Forum for a long time.
    For me in the past I use the Adobe Bridge to have an overview of all my clips. I manage them in Folders by resolution and kind of style.
  • mimi45
    by mimi45 » Wed Oct 29, 2025 6:16 pm
    Since macOS Catalina no longer supports 32-bit QuickLook plugins, older HAP thumbnail generators won’t work. The best workaround is to install a modern QuickLook plugin that supports Catalina, such as qlVideo or BetterZip Quick Look generator, which can display thumbnails and previews for many video formats including HAP. Alternatively, you can use MadMapper or QuickTime Player (with HAP codec installed) to preview the files directly until an updated HAP QuickLook plugin becomes available.
    regards: mimi [Nulls Brawl]
