(lpn) Media Set Load (master) Module Issue - V3.1.7
  • radiofreebc
    by radiofreebc » Thu Jun 04, 2020 11:53 am
    I have been using Modul8 V2.9 for years, but had to upgrade my Mac to OS Catalina today. After upgrading the OS, I discovered I also had to upgrade my Modul8 software from V2.9 to 3.1.7. So, I bought the upgrade and migrated all my old modules to the new folder.
    However, I've noticed a serious issue with the (lpn) Media Set Load (master) module. In the previous version, the list of preset mediasets displayed in the module was ordered...in the order I added them to the module (which was numbered from 000-254). However, when I now run the module, the preset mediasets in the folder are not displayed sequentially anymore.
    I am hoping there is an fix, as this is a module I use all the time to organize/load/clear my media. I've looked through the code, but I'm not a coder, so I was unable to figure anything out. If anyone can help me get this fixed, that would be greatly appreciated...since this module is really the centerpiece of how I organize my clips/mediasets. I'm not sure of any other modules that can organize a large number of mediasets like that.
    Screen Shot 2020-06-04 at 4.14.06 AM.png (226.73 KiB) Viewed 11003 times
  • radiofreebc
    Re: (lpn) Media Set Load (master) Module Issue - V3.1.7
    by radiofreebc » Thu Jun 04, 2020 7:28 pm
    Solved it. I needed to add a line of code to the script:
    # Media Set Load module
    # Written by VJ Danger modified by Gael Abegg-Gauthey aka Lupin - 2012
    # ©© This module is licensed under a Creative Commons 3.0 Attribution - Non commercial - ShareAlike license.
    # To view the license follow this link: http://creativecommons.org/licenses/by-nc-sa/3.0/
    # If you wish to use this module commercially (ie. for paid public performance, etc.), please contact me to authorise usage.
    # Comments, suggestions, donations:- gael@mrlupin.com
    if modul8.getValue ('direct_version',0) < 2.55 :
    module.stop();
    import os, urllib
    from xml.dom import minidom
    from xml.dom.minidom import Document
    file_list=[]
    def refreshtree(basepath):
    mediasets = []
    print basepath
    i=0
    #file_list=[]
    if os.path.isdir(basepath) :
    for fn in os.listdir(basepath):
    ext=fn[len(fn)-4:]
    if ext==".m8s":
    file_list.append(1)
    file_list=fn[:-4]
    i=i+1
    file_list.sort(key=int)
    module.setAttribute('mediasets_list','TEXTLIST',file_list)
    def clearMediaset(nset):
    for n in range ((int(nset-1)*16),(int(nset-1)*16+16),1):
    modul8.setValue('direct_media_change',[n,'' ],0)
    def clearAllMediaset():
    for n in range (128):
    modul8.setValue('direct_media_change',[n, ''],0)
    basepath=os.getenv('HOME')+'/mediasets/'
    if not os.path.exists(basepath):
    os.makedirs(basepath)
    module.setValue('basepath', 0, basepath)
    I added the "file_list.sort(key=int)" line to it, and it works perfectly.
