Unplug MiniMAD while running?
    Re: Unplug MiniMAD while running?
    by MADben » Thu Jul 02, 2020 10:41 am
    You can definitely use a timer as described,
    However in some situations where space is limited, the MiniMad units might get hot. If too hot for a long time, data corruption may appear on entry level SD-card. In these situations you should use an Industrial/Military grade SD card
    Units ran for more than a year in suitable environments (with Industrial Grade SD card and well aired)
