Big Sur Compatibility
  • ylandsman
    by ylandsman » Wed Aug 26, 2020 10:08 pm
    Has any testing been done with the Big Sur beta? Ared there any issues? If so is there a timeframe to deal with them? Thanks
    Re: Big Sur Compatibility
    by Pierre Guilluy » Tue Oct 27, 2020 10:57 am
    Modul8 isn't macOS Big Sur compatible.
    We're in the process of fixing some issues, but debugging those requires a lot of changes in the development environment, so we're not sure yet when an update will be ready.
    In a general manner, we strongly advice against updating to a new OS version on day one, and until the critical softwares you're using are declared compatible.
    If you want to give the OS a try, I would suggest installing the new OS version on a separate partition, or better on an external disk.
  • ylandsman
    by ylandsman » Mon Dec 07, 2020 2:31 pm
    It is already over a month since the release of Big Sur, and I really want to upgrade. Modul8 is the only application that is holding me back. Is there any eta yet, for when Big Sur will be supported by modul8?
    by Pierre Guilluy » Tue Dec 08, 2020 2:40 pm
    We're working on it, but the task is not as easy as expected.
    Sorry for the delay.
    by boris » Wed Feb 17, 2021 6:02 pm
    Big Sur version is released !
    viewtopic.php?f=1&t=35356
  • haseem alam
    by haseem alam » Tue Feb 06, 2024 7:21 am
    Thanks for sharing.
Users browsing this forum: No registered users and 46 guests
