cue scheduler issue
  • malasombra
    cue scheduler issue
    by malasombra » Mon Sep 07, 2020 5:22 pm
    Hi, I'm trying to automate some cues with the cue scheduler. I think everything is correct (year, month, day, start specified cue, row, etc. etc). But it doesn't work and I don't know why. "Go Next Now" work fine.
    I use madmapper 3.7.8.
    any suggestions?
    thanks!
    Re: cue scheduler issue
    by mad-matt » Tue Sep 08, 2020 2:17 pm
    Which version of MadMapper ? I remember we fixed an issue when combining scheduling and automation.
    Do you want to automate or to schedule ?
    Post a screenshot of your settings maybe ?
  • malasombra
    by malasombra » Thu Sep 10, 2020 10:22 am
    I have been trying different settings and when I select the year (2020) it never works for me. But when I select "each" in the "year" tab, it works. I'm starting to doubt what year I live in! :shock:
    I have tested on two different laptops and with V3.7.8 and also with v4. The result is the same. With only scheduler, only automate, and both.
    by mad-matt » Thu Sep 10, 2020 2:43 pm
    Indeed there's a bug in 4.0 with "Schedule" / "Year". All others are working perfectly. It's in our bug tracker. Will be fixed in 4.0.1.
    Thanks for reporting !
