Custom shader texture input?
  • julianlumia
    by julianlumia » Wed Sep 09, 2020 6:12 pm
    Soo i have a shader question,
    is it possible to use the output of a material as an input texture in the material editor?
    To specify a bit further what I'm trying to achieve, I made a quick mockup in shadertoy:
    https://www.shadertoy.com/view/tl2Bzd
    I know how to convert the shader to a MM material, but I can't figure out how to reference a texture from another quad layer :(
    So basically in the example line 7 on shadertoy:
    vec4 col = texture(iChannel0, uv1);
    I need to replace "iChannel0" with something referencing the texture of another MM material.
    Anybody here know how to do this? Is something like this possible? :)
  • julianlumia
    Re: Custom shader texture input?
    by julianlumia » Wed Sep 09, 2020 6:56 pm
    Welp never mind I solved it by looking at an example of how this was done in ISF shaders:)
  • jasonbeyers
    by jasonbeyers » Fri Oct 23, 2020 8:52 pm
    With Madmapper 4.x, you can drag Materials into the "Generator" section of the media bin to instantiate a "Material Player" with that Material, with configurable resolution. When you do this, that Material player will show up in the texture input drop-down menu for other media (including other Materials or any ISFs).
    This added step is not necessary if you just want to use an ISF as a texture input for something else.
