Sincronizzare madmapper e ableton live, come?
  • Oddagency2019
    by Oddagency2019 » Thu Sep 24, 2020 2:32 pm
    Buonasera,
    Volevo capire se era possibile (anche nella versione 4 di MM ) sincronizzare la barra di avanzamento video timeline, di Madmapper con una traccia timecode eseguita su Abelton.
    Grazie!!
    Re: Sincronizzare madmapper e ableton live, come?
    by mad-matt » Thu Sep 24, 2020 9:51 pm
    You can use a Max 4 Live plugin called Live MTC Bridge. Then you can assign a MIDI Timecode Control to the movie position ("/medias/myMovie.mov/position_sec"), but you have to keep your movie in pause mode, which means you won't get the movie audio tracks playing, which is not an issue since I suppose Live is the audio source.
  • Oddagency2019
    by Oddagency2019 » Fri Sep 25, 2020 3:25 pm
    Sai anche dirmi il setting delle impostazioni su madmapper? il video parte e pare muoversi con la timeline di ableton ma non risulta scorrevole, va a scatti e diventa nero :(
    by franz » Thu Oct 01, 2020 12:35 pm
    is your movie 30fps ? MTC is 30fps steps as far as I remember - I could be wrong -
    you could also try to send an OSC float from ableton live to MM, and assign the float to your movie position
