Photogrammetry 3D object
  • buffy999
    by buffy999 » Fri Sep 25, 2020 3:43 pm
    I want to map a large odd shaped boulder. I don't have a Canon camera for spacial scanner.
    Is it possible to make a 3D object by using photogrammetry?
    Would it work in MM?
    Does anyone have experience in this type of project?
    Is it too complicated for a beginner?
    TIA
    Re: Photogrammetry 3D object
    by franz » Sun Sep 27, 2020 6:31 pm
    totally doable,
    done it quite a few times.
    You'd need to understand a few things about 3d objects tho
  • buffy999
    by buffy999 » Mon Sep 28, 2020 11:30 am
    thanks franz
    can you guide me to some instructions or a tutorial on 3D objects?
    by franz » Thu Oct 01, 2020 12:23 pm
    it really depends what software you'll be using ..
    3dsmax, maya, houdini, blender, c4d ...
    they all share the same concepts, but the workflow is different.
    I'd start to learn one.
    And start practicing with photogrammetry using RealityCapture, PhotoScan or any other app.
    Export as .obj and load up the file into madmapper.
    We're working on a 3d calibration guide at the moment.
  • buffy999
    by buffy999 » Fri Oct 02, 2020 3:01 pm
    thanks franz
    i've created a 3D model using the Trnio app and imported it into MM as an obj file.
    I havent calibrated it or tested it as a projection, but should this work?
    Or do I need to first use the 3D modelling software you mentioned?
    The only information I can find is the MM 3D calibration video.
    by franz » Wed Oct 07, 2020 10:57 am
    once you have an .OBJ file that you can import into MM, and that correspond to a real object you're trying to map, you're good to go.
    Plus, in mm v4, we've added triplanar mapping option which allows you to map any object without having UV coordinates.
    For a perfect calibration, be sure to AVOID using a short-throw projector lens.
  • buffy999
    by buffy999 » Thu Oct 08, 2020 6:18 am
    thanks franz I'll try it
