MiniMAD + KIOSC (Really just OSC questions)
  • stphntylr
    by stphntylr » Thu Oct 08, 2020 3:13 pm
    I have a minimad based installation that I have just updated to MadMapper and MiniMad 4.
    I am using the OSC based app called KIOSC to try and build a remote control interface for the client, I cant seem to get it to work.
    I have used the templates available for TouchOSC and they seem to work great.
    However before you tell me its a problem with KIOSC, which obviously it is, what stumps me is when I look at the templates in TouchOSC. The tags and controls in the TouchOSC. mostly do not reflect what is listed in the documentation.
    Example to control Luminosity
    The Manual says:
    - /set_master_luminosity + float OSC value: set the master luminosity
    The Touch OSC is using:
    /master_luminosity/all with a range from 0 to 1.
    Exmaple to Trigger Media Index 1:
    The Manual says:
    - /set_sequence_by_index/{sequence index}: set the current sequence by index, example: /set_ sequence_by_index/2 to play the third sequence
    /media_index/0
    So my questions are:
    1. Is there a more comprehensive list of the OSC commands that the MiniMad will accept that would include these flags they are using in the templates?
    2. Any one familiar with KIOSC have any insight as it may be possible I am not doing something right here?
    Thanks for the help!
    Re: MiniMAD + KIOSC (Really just OSC questions)
    by Pierre Guilluy » Mon Oct 12, 2020 12:03 pm
    It seems like you're referring the MiniMad 3 OSC commands.
    Here's the official link to the MiniMad 4 User-Guide:
    https://madmapper.com/wp-content/upload ... 9-2020.pdf
    Corresponding MiniMad 4 TouchOSC layouts are available on MadMapper Yourspace.
