problem material "siren"
  • audeloic
    by audeloic » Fri Oct 09, 2020 4:18 pm
    I just start using madmapper
    I have a problem with the animation in material strob, random, siren, sphere ... it's not working anymore, even with the full speed nothing works. do you have any solutions? (it worked yesterday and since nothing)
    version and madmapper 4.0.1 on windows 10
    Thank you for your help ! :D
    regards
    Re: problem material "siren"
    by mad-matt » Tue Oct 13, 2020 10:00 pm
    Is it possible that you BPM is set to zero ?
    Check out in Master Tab. Maybe set the Global BPM to mannual / 120 BPM.
