OSC commands for MiniMad
  • LaurentR
    by LaurentR » Mon Oct 19, 2020 5:41 pm
    Hi folks,
    We've been looking for the complete OSC commands to drive the MiniMad modules we ordered. It seems that the documentation about this topic is not complete.
    We've been using Wire shark to check some of the command lines sent by the PC and for example /replay seems to be a defaut command and missing extra parameters ( if you send /replay 0,000 there's no "loading" message displayed on the monitor to replay video 0).
    The module is also sending feedback status (ACK) that can be really hepful.
    Do you have extra information available?
    Thanks for your support,
    Laurent
    Re: OSC commands for MiniMad
    by Pierre Guilluy » Tue Oct 20, 2020 10:42 am
    You will find all necessary information about MiniMad 4 in the official user-guide available on Yourspace and https://madmapper.com/minimad/
    Is there something missing?
    by Pierre Guilluy » Fri Nov 06, 2020 10:53 am
    We've had a problem with the forum and the two latest posts - including my latest answer - have been erased.
    Anyways, we've indeed made some mistakes in the OSC command list of the MiniMad 4 user-guide, sorry for that!
    Here's the updated / fixed version: https://madmapper.com/wp-content/upload ... _GUIDE.pdf
