MadMapper 4.0.3 available!
    by MADben » Fri Oct 30, 2020 12:42 pm
    Dear Mappers,
    MadMapper 4.0.3 is now available with a couple of updates :
    IMPROVEMENTS
    * Added spill suppressor parameter to Chroma Key surface FX
    FIXES
    - Fixed discarding some physical or virtual DirectShow video-input devices, including nVidia Broadcast and Spout Virtual Webcam (Windows)
    You'll need this version + Windows 10 if you want to use MadMapper for live streaming like in this fresh new tutorial! -> https://www.youtube.com/watch?v=2GtTxHNCzzs
    The previous MadMapper v4.0.2 already brought a bunch of fixes and improvements:
    MadMapper 4.0.2. Release Notes
    ADDITIONS
    + Added an option to copy mesh warping (right click on surface in output preview or surface list to copy, then select the target surface and paste)
    + Added support for new frequencies in MiniMad Video: 24, 25, 30
    IMPROVEMENTS
    * BlackMagic: warning when installed Desktop Video version is outdated (can be disabled in preferences)
    * ArtNet / sACN: add "localhost" interface on Windows
    * Cue Scheduler:
    - When using movie loop end switch, be accurate (donnot check only once per second)
    - Changed the Play Once mode behavior so it restarts when entering schedule time range again + added "Go First Now" button to reset playback
    - Accept Scheduler End Hour/Minutes lower than Start Hour/Minutes, meaning end time is on the next day
    * Handle "CUE ALL" + “select” Control on textual media list & fixed dragging item in Edit Cues mode
    * Improved MiniMad Light performance driving many universes
    * Code Editor current zoom is now saved in the settings
    FIXES
    - Blackmagic: fixed possible issue with devices that supports several pixel-formats for the same input connection & resolution
    - Fixed editing line surface / line thickness in pixels when surface is rotated
    - Fixed bug when exporting several times the same media to MiniMad Video
    - Fixed issue with triangles in MiniMad Video
    - Fixed audio glitches in Audio Player and WAV or uncompressed audio files
    - Fixed Audio Player playing at max volume when audio level was changed when stopped
    - Fixed handling cue column settings when deleting a column
    - Material Player generator wasn't handling “restart” (button & control)
    - sACN: ignore DMX packets with specific DMX start code different (solves issue controlling MadMapper through sACN from some controllers)
    - Fixed multiple selection in MadLight Recorder
    - Fixed issue when zooming in an empty Code Editor
    Enjoy!
    The MadTeam
