Lasers
  • sputnik
    Lasers
    by sputnik » Fri Nov 06, 2020 10:14 pm
    Does anyone have any experience implementing lasers into MM. I understand this would be possible thru DMX
    By using Garagecube DMX controller for instance ? https://shop.garagecube.com/collections ... 1-universe . Or rather independent hardware is required.
    Is there any simple/basic budget friendly laser , DMX controlled out there ? And would it possible to work with it like for example with Garagecube LED Bars ? Any tip appreciated.
    Re: Lasers
    by mad-matt » Sat Nov 07, 2020 12:02 am
    Of course if you have a DMX controllable laser you can control it from MadMapper.
    You might have to create a custom fixture definition. In MadMapper a fixture definition tell which channel is control by what (input visual color levels / sliders / fixed value or custom coded expressions). We do a lot of shows controlling strobs, lights, LED bars & video at the same time, if we had DMX lasers we could do it too.
    If you have a PDF forr the DMX control you can post it, it generally takes 5 minutes to create a fixture definition.
  • sputnik
    Re: Lasers
    by sputnik » Sat Nov 07, 2020 12:33 am
    Hi Matt,
    Thank for speedy response. I'm still in process of understanding the whole 'laser' thing, as it is not so straightforward to me right now.
    If for example I want to project a custom animation ? You are saying 'PDF' - that means still img ? . I was looking at https://www.laseros.com/ and their LaserCube . But it looks like a closed system. Ie. if you want some custom animation content, there is a payable service to do that.It does not look as simple as attaching custom animation to MM quad ?
    I'm also keen to use Korg Nanokontrol 2 MIdI controller to play with it..if it is of course parametric MM content/material
    I think there is still sth I'm missing here..which I don't understand in whole workflow :)
  • Calysto
    Re: Lasers
    by Calysto » Sat Nov 07, 2020 4:46 pm
    Custom laser animations are made with special software like Pangolin Quickshow. You need a laser that supports ILDA (more info: google)
    You need an ILDA interface connected to an ILDA-laser.
    If you want, you can send DMX commands to the ILDA software to make a nice show.
    With PDF he ment a manual.
    Just sending DMX is possible too, but your options are very limited then, no custom animations, only build-in animations. Unless you have and Pangolin FB4.. you can upload animations to the FB4 and run them with DMX-commands.
    In a nutshell... just google until you die...
    There might be some opensource ILDA controllers, but be careful, a laser is dangerous, don't 'just do something'.
  • sputnik
    Re: Lasers
    by sputnik » Sun Nov 08, 2020 12:37 pm
    Thanks @Calysto . That is a good lead ! I will take it from here ,and apply myself death by Google ,as always :)
  • Calysto
    Re: Lasers
    by Calysto » Sun Nov 08, 2020 4:29 pm
    :D
