MadMapper 4.0.4 Released
    by MADben » Wed Dec 09, 2020 12:22 pm
    Dear Mappers,
    We just released the 4.0.4 update which comes with a new FX as well as a bunch of improvements and fixes..!
    Available as usual on Yourspace -> https://madmapper.com/yourspace/
    MM 4.0.4 Release Notes
    ADDITIONS
    + Added FX “Channels Shuffle”
    IMPROVEMENTS
    * Line Surfaces: in creation mode when Show Info is enable, display stronger line to mouse on the projector
    * Line / Mask edition: improved undo/redo behavior in creation mode
    * MadLight Recorder: when recording DMX input, use interface url selected in preferences / DMX Input
    FIXES
    - Fixed material shader files from templates not being correctly named
    - MiniMad Light: Fixed glitches in audio playback when playing sequence in loop
    - MiniMad Light: Fixed OSC sequence trigger
    - MiniMad Light: Fixed OSC playing status after changing sequence
    - MiniMad: Fixed faulty OSC commands in embedded user-guide
    - Cameras on Windows: fixed possible issue when a device is not supported by MadMapper
    - Fixed Cue Scheduler issue with multiple Cue Banks
    - Audio Player & Movie Audio: fixed audio glitches with some codecs
    - Fixed showing media popup menu by right clicking a media text view
    - Fixed a possible fullscreen issue with Spatial Scanner on Windows
    - sACN in: join multicast goup with selected network interface (on macOS it was only getting sACN fom the first active network interface in the OS)
    - Fixed controls / cueing for surface 3D lighting enabled + wireframe_enabled
    Enjoy!
    The MadTeam.
