WS2801 v Arduino Uno- MadMapper Problem
  • alexander034
    by alexander034 » Wed Dec 09, 2020 6:12 pm
    I try to made the LED tutorial files that i download from archive.
    I select my WS2801 led in the Arduino sketch.
    Upload the sketch, run correctly and the MadMapper is communicate with the arduino board, i see the dmx lines..etcetc but the LEDs not working.
    Just test the LED lines are work correctly.
    Where is the problem?
    Re: WS2801 v Arduino Uno- MadMapper Problem
    by MADben » Fri Dec 11, 2020 1:13 pm
    which LED tutorial file did you use? it may be outdated
  • alexander034
    by alexander034 » Fri Dec 11, 2020 8:17 pm
    MadMapper_LED_Tutorialfiles.zip i found in the archive.
    I try to found the solution. When i changed the baud rate, the led is working but very glitchy.
    The first problem is the Arduino Uno...too slow i read a post in the forum.
    I ordered a TEENSY and i try again :)
