MM 3.7.8 Kinect Masker set up help
  • JamesCamargo
    by JamesCamargo » Sun Dec 20, 2020 5:10 pm
    HI guys,
    I'm trying to get my kinect one working on the MM 3.7.8 using the internal Kinect Masker generator.
    When the MM launches and the kinect is pluged in it already shows the generator"Kinect Masker", but I wont see any image from the kinect cameras on the screen. It also shows the 3 cameras from the kinect on the live input cameras list, but same problem, I wont see any image coming from them.
    There's any other thing that I must do to get it working?
    Im running it on a macbook air with macos catalina 10.15.7.
    Kinect One model 1520
    Thanks
    Re: MM 3.7.8 Kinect Masker set up help
    by franz » Wed Jan 06, 2021 2:13 pm
    Kinect Masker is discontinued
  • JamesCamargo
    by JamesCamargo » Thu Jan 14, 2021 2:42 am
    I know that the app is discontinued, but the one running inside the mad mapper doesn’t work too?
    by franz » Fri Jan 15, 2021 2:20 pm
    should be working but untested on Catalina.
    Unfortunately I don't have a Kinect at hand to test on my side.
    I'll dig the subject.
    by franz » Fri Jan 15, 2021 2:22 pm
    Kinect is dead on Catalina, driver unsuported.
    We won't be fixing this, but might support Intel Realsense in the future instead.
  • JamesCamargo
    by JamesCamargo » Mon Jan 18, 2021 5:49 pm
    Thanks Franz
  • yanoul
    by yanoul » Wed Jan 05, 2022 1:31 pm
    Jumping on this thread. :mrgreen:
    Is there any update, tests, sample or other stuff about intel realsense with MM or Mod8?
    by mad-matt » Thu Jan 06, 2022 6:58 pm
    We bought two real sense devices and just had a few things left to solve but since the product has been discontinued we haven't finalized... I think we clean the Kinect ONE support and add it on Windows at some point. I'm not that happy with latency / depth resolution but we have no much better to propose...
  • yanoul
    by yanoul » Fri Jan 07, 2022 10:30 am
    Thx for updating me.
    Some products as been stopped but others continuing and SDK 2.0 will be updated.
    https://www.intelrealsense.com/message-to-customers/
    Hope you will publish on a next release. I’m actually using it in Unity and stream back to MM but a smoother approach would be nice.
    Best,
    Yan
