MadMapper Text Generator CURSOR
  • blaus_binski
    by blaus_binski » Mon Jan 11, 2021 12:03 pm
    Hi There
    First of all, i apologise for my english and I'm also new to MadMapper.
    So, for a theatre-Show i'm looking for a way for one of the actors on stage to type text live via remote keyboard - which is then projected on stage.
    Now, if I use a quad, as you would, only the first few words are shown. After a while, the "cursor" is situated "outside" the quad.
    Are there any options to "lock" the cursor to the quad or something like that?
    I already tried to activate scrolling. But it doesnt have the required effect.
    Another possibility would be to sort of align the text within the quad. But i can't see any way of doing that.
    Thanks
    Re: MadMapper Text Generator CURSOR
    by mad-matt » Tue Jan 12, 2021 9:37 pm
    If I understand correctly, you're using the Text Generator ? Or are you getting an NDI stream from the computer on stage ?
