MadLight Recorder, no OSC Play-Trigger?
    mipmarple
    by mipmarple » Thu Jan 14, 2021 11:34 am
    I am struggling to replace a constantly unreliable mediaserver (DynamicProjection MDC Shuttle PC) with an intel Nuc running MadMapper.
    My goal is to trigger plaback of two videos, 5.1 sound and an artnet sequence which I recorded using the new MadLight Recorder feature. Recording and cutting of the artnet Sequence worked very well, and I can verify its content using the DMX Monitor.
    *BUT* it doesn't seem to be possible to trigger playback of the scene via OSC?
    I can only trigger "Start Recording" and "Stop Recording".
    Is there anything about the concept I misunderstand?
    I could export it to a miniMad, which I have here, but I would really like to omit any Hardware that is not necesary here.
    Thanks + Greetings.
    Re: MadLight Recorder, no OSC Play-Trigger?
    by MADben » Thu Jan 14, 2021 1:21 pm
    there's a list of OSC commands for MiniMad Light in this manual : https://madmapper.com/wp-content/upload ... _GUIDE.pdf
    (you should find what you need there)
    mipmarple
    by mipmarple » Thu Jan 14, 2021 9:51 pm
    Controlling the miniMad is no problem, but shouldn't it be possible to just playback a recorded Artnet-Sequence in madMapper?
    by MADben » Fri Jan 15, 2021 6:56 pm
    Artnet sequences recorded with the MadLight recorder are intended for the MiniMad - hence the "limitation"
    there is still a way to use them though, I'll sent you a file in pm shortly
