Poor performance on MM4
  • barakchamo
    by barakchamo » Wed Jan 20, 2021 8:22 am
    Hi there,
    I have a MiniMad model 2 and just tried updating it to MM4.0.4 for the first time.
    Running a very simple recording, with 4 universes at 30 fps results in very poor performance, whereas with MM3 I never had these issues.
    Recording in MadMapper 4 runs smoothly, and playing back the recording does as well, but the playback in the MiniMad is choppy and slow.
    Anyone had similar issues with the new software?
    Edit:
    Just adding to this that I tried unicast and multicast, and running LEDs over artnet with wired Ethernet - same setup as I've been using for very long with no issues.
    Re: Poor performance on MM4
    by Pierre Guilluy » Tue Jan 26, 2021 12:37 pm
    Are you controlling the MiniMad using OSC?
    Could you contact the support, so you can send us a sequence you have performance problems with?
