MadMapper 4.0.5 + 3.7.9 available
    by MADben » Tue Jan 26, 2021 12:26 pm
    Dear Mappers,
    After some waiting, the whole team is happy to present you these two new versions
    Indeed MadMapper versions 4.0.5 and 3.7.9 are now available: in addition to bringing new FX (4.0.5), they also and especially fix the known UI and NDI bugs on macOS Big Sur
    These two versions allow you to use MadMapper properly on macOS Big Sur, but do not hesitate to share any feedback with us
    Available as usual on Yourspace -> https://madmapper.com/yourspace/
    MM 4.0.5 Release Notes
    ADDITIONS
    + Addition "Center" and "Entier Media (Preserve Ratio)" options in Input View popup menu
    + Added FX Voronoize & Emboss
    IMPROVEMENTS
    * Improved performance with multiple outputs on macOS with Intel GPU
    FIXES
    - Fixed some UI refresh issues on macOS Big Sur
    - Fixed NDI on macOS Big Sur
    - Fixed few other macOS Big Sur issues
    - Material Generators were Y flipped
    MM 3.7.9 Release Notes
    IMPROVEMENTS
    FIXES
    - Fixed issues on macOS BigSur (NDI output & few UI refresh problems)
    Enjoy!
    The MadTeam.
    cvanhoose
    Re: MadMapper 4.0.5 + 3.7.9 available
    by cvanhoose » Tue Jan 26, 2021 7:12 pm
    I have an urgent issue.
    MM4.0.5 won't open in Windows 10.
    libssl-1_1-x64.dll not found
    libcrypto-1_1.dll not found
    cvanhoose
    by cvanhoose » Tue Jan 26, 2021 7:38 pm
    Is is possible to download 4.0.4 as an emergency?
  • AEK_98
    by AEK_98 » Tue Jan 26, 2021 11:26 pm
    I confirm, MM 4.0.5 does not open in Win 10/64.
    I already wrote about this on Facebook this afternoon.
  • j3kassabian
    by j3kassabian » Wed Jan 27, 2021 4:05 am
    I just had this problem upon installing a fresh version of Windows + MM.
    I found my system was missing OpenSSL which I downloaded from here:
    https://slproweb.com/products/Win32OpenSSL.html
    I did not download the light version, and after installing I was able to start MM without the need to reinstall.
    Hope this helps!
    by MADben » Wed Jan 27, 2021 10:17 am
    we're currently fixing the issue (a proper 4.0.5 will be available shortly)
    until then feel free to contact the support in order to get a direct link for MM 4.0.4
    our apologies for the inconvenience
    by mad-matt » Thu Jan 28, 2021 10:11 am
    We updated MadMapper 4.0.5 for Windows to fix this issue. Latest version on yourspace will work as expected. Sorry for this issue.
    by mad-matt » Mon Feb 01, 2021 11:26 am
    Hi Johan,
    I had such other report from a user on macOS 10.13. Can you tell me what you os version is ? And computer specs ?
    Kind Regards,
    Matthieu - MM team
    by mad-matt » Mon Feb 01, 2021 9:29 pm
    Ok,
    It seems to be an issue with macOS 10.13 and the build we did with macOS 10.15 SDK.
    Please download from yourspace the MadMapper build for older macOS releases. It works perfectly on macOS 10.13.
    Kind Regards
    Matthieu - MM team
  • jasiyo4685
    by jasiyo4685 » Mon Mar 25, 2024 12:16 pm
    https://slproweb.com/products/Win32OpenSSL.htmltime card calculator
    Hope this helps!
    Gracias por compartir la información, es realmente útil.
Users browsing this forum: No registered users and 66 guests
