Cannot find user-installed fonts on Windows
  • sebescudie
    by sebescudie » Fri Feb 05, 2021 12:05 pm
    Hello there,
    Using MM 4.0.5 on W10, I'd like to use manually installed fonts for the text generator. Unfortunately, those won't show up in the Font dropdown. I made sure they're ttf fonts and tried three different ones, but none of them show up.
    These fonts all show up in other softwares such as LibreOffice Writer.
    Repro steps :
    - Download this font from FontSquirrel
    - Install it
    - Start MM and try to assign it to a text generator
    - The font is not present in the dropdown
    Happy to provide more details if necessary!
    Thanks in advance.
    Re: Cannot find user-installed fonts on Windows
    by mad-matt » Sat Feb 06, 2021 11:03 am
    Ok, there might be an issue looking for user fonts on Windows in the Text Generator module.
    It's actually looking in C:\Windows\Fonts\. Do you know where your font was installed ?
  • sebescudie
    by sebescudie » Sat Feb 06, 2021 12:51 pm
    Mornin'
    Indeed, Windows control panel says the font was installed in C:\Users\user\AppData\Local\Microsoft\Fonts.
    Screenshot here
    If I browse to this folder, I see all fonts I have manually installed
    Screenshot here
    Weird thing is if I browse to C:\Windows\Fonts, the font also shows up there :
    Screenshot here
    by mad-matt » Mon Feb 08, 2021 11:34 am
    Is your font in ttf format ? (file with .ttf extension)
  • sebescudie
    by sebescudie » Mon Feb 08, 2021 3:00 pm
    Hello there,
    It is indeed :
    Now, looking a bit more at the C:\Windows\Fonts folder, Windows shows it as an OpenType font :
    by mad-matt » Mon Feb 08, 2021 4:15 pm
    I suppose that's why it doesn't appear. We rely on a library that only supports True Type fonts. I know some don't work.
    In the mean time we've been working on another text renderer that is more robust and cross-platform. So I suppose next MadMapper feature release will find all your fonts.
